Game servers RWG-team
Модератор: zarathustra
We introduce the Hamachi alternative from the RWG-team!
Currently, the system works in a free mode.
The service is provided free of charge, all the costs of creating and maintaining servers are covered by the RWG-team.
The game network is created through vpn connections (tunnels) to our servers.
The indisputable advantage of this solution is the comprehensive support of this type of connection in any version of Windows and the absence of the need to install anything on your PC.
To simplify the process as much as possible, an exe file has been written for automatically creating a VPN with all the necessary parameters: Four languages are traditionally supported:
  • Russian
    English
    Deutsch
    French
The launch is made in the system layout of the OS (in the Windows installation language).
For evaluation, you can use these test accounts (login):
  • Gamer
    Gamer1
    Gamer2
    Gamer3
    Gamer4
    Gamer5
    Gamer6
    Gamer7
    Gamer8
    Gamer9
Password (it is the same for all accounts):
  • Gamer
It is not advisable to use test accounts for constant play (because in this case lose your personal identification and you will have to pick up a free account each time you play).
For unique identification, you need to send the desired username/password to support@realwargame.ru and wait for confirmation (response letter).
IMPORTANT!
Login - letters ONLY in the Latin layout and/or alphanumeric, in one word (a login that does not have a meaning or that is obscene will be rejected).
Password - letters ONLY in the Latin layout and / or numbers, symbols (The case the of letters matters - the server distinguishes between uppercase and lowercase letters!)
Additional manual
For all questions related to the operation of the service, please contact our support team.
The RWG-team wishes you a pleasant game!
Note: servers do NOT provide access to the Internet, i.e. for example, you cannot use them as a proxy.
Re: Game servers RWG-team
The following rooms have been created for players to communicate:
Discord
Possible problems:
1. Failed to connect to the RWG VPN server (error 809). In the main reason a client behind the NAT unable to forward VPN tunnel.
You must enable NAT Traversal protocol support in Windows - you need to create/change registry value:
«Start» => «Run» => «regedit»
«HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Services/PolicyAgent»
Set 2 value to DWORD-32 «AssumeUDPEncapsulationContextOnSendRule» (without quotes) parameter
Or run the reg-file from the archive: Nat.zip - it will set/change this parameter automatically.
We reboot the computer to apply the settings.
* On some models of routers, it is additionally required to activate the Passthrough protocol:
Optional => (IGMP/ALG/) Passthrough => allow the router to use the L2TP/IPsec pass through protocol.
2. L2TP connection attempt failed (error 789) - Windows cannot create the L2TP connection without an IPSec pre-shared key.
In order to allow password authentication, you must create (or change) the value in the registry:
«HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Rasman\Parameters»
For parameter (RegValue DWORD-32): ProhibitIpSec set value 1
For parameter (RegValue DWORD-32): AllowL2TPWeakCrypto set value 1
Or run the reg-file from the archive: Key.zip - it will set/change this parameter automatically.
I would like to remind those who go online through a router: to play, you must disable the Universal Plug and Play (UPnP) function - otherwise you will not see the created server (host) or will not be able to connect to the game.
The RWG-team team presents to your attention an updated version of the VPN connection configurator:
  • Removed unused tabs and settings
    Added auto-reconnect feature
    Updated guide
    German manual added
    Reg-files added to the archive
Links in the header have been updated, duplicated below:
Due to the increasing problems in some countries with access to our game VPN server (due to blocking Internet traffic), we decided to create a channel in Radmin:
LAN Radmin: RWG ToW
Pass: 123456
To improve communication, a Telegram group has been created
