sound in menu?
Forum devoted to open discussion of the project RWG and all that it involves.
Модератор: zarathustra
mayor
sound in menu?
Сообщение mayor »
hello guys, i hope you all ok and not have any problem with this virus.
can somebody tell me how to set which audio file will play in menu? what files for that?
thanks
Re: sound in menu?
backwav - the main theme is played in the menu.
briefing - music plays before launching missions during the briefing.
winwav - music plays when you win.
loosewav - music plays on defeat.
Format: RAW packaging, 22kHz, 16bit, stereo.
The format can be used wav (mono, no more than 16 bit and no more than 44 KHz), but the playback quality will be worse.
mayor
Re: sound in menu?
Сообщение mayor »
understand, but what tools need to open this files?
Re: sound in menu?
mayor писал(а):understand, but what tools need to open this files?
Any RAW editor or player. But there is a problem: the RAW-format does not contain parameters in the header and for playback you need to specify them manually
